eclark
Apr 27, 2016Aspirant
Can I have two ReadyNas 316 (or another model) systems auto back up to one another?
Hi! I am a professional photographer and we are looking for a streamlined solution for our photo and video backup. I would like to have one ReadyNas system at my studio and then have it both back...
Apr 27, 2016Guru - Experienced User
It is possible. You can use replicate to back up to the system at your house.
There are a couple of options to back up to the cloud. What make sense there depends on what cloud service you are talking about. I use crashplan on my pro-6 - that needs to be manually installed with ssh and requires some linux knowledge. Though you can alternatively install crashplan on a windows-10 system, and mount the NAS volume as a network drive - backing up the NAS through the windows 10 system.
Amazon Cloud sync is in beta, I am not sure if it is ready to do what you want yet.
You could also use Egnyte, you'd need to contact them for pricing. But it looks like you'd get 10 TB of cloud storage with a single-employee license for $15 per month.
JennC
Apr 30, 2016NETGEAR Employee Retired
Hello eclark,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
