miogpsrocks's avatar
Dec 09, 2018
Can I install Plex on my readynas? Firmware 6.9.2 readynas Pro
Shoudl this be in the app store on the unit itself or does it take more work to install this?
Are there any instructions if so?
Thanks.
    • Sandshark's avatar
      Sandshark
      Sensei
      If by "Pro" you mean the older Pro Pioneer or Pro Business Edition and you plan to have the NAS do any video transcoding, you will likely want to upgrade the processor and memory.  If it's the newer "Pro6", then just increasing memory is advised.
ProSupport for Business
