maduhbee
Feb 23, 2015Follower
Can I use 8TB drives in my 104
Ready NAS 104 and Synology DS213 user. DS213 has been running for > 2 years w/o issue. Just got the 104 to expand storage. I saw these Seagate 8TB drives for less than $300 a pop. Planning on Ru...
mdgm-ntgr
Feb 26, 2015NETGEAR Employee Retired
One thing I should add is that some high capacity disks are designed a bit differently to most disks and may not fit in the drive trays. That is another thing to consider in addition to the disk not being on the compatibility list.
