Plumiere
May 25, 2017Aspirant
Can'complete OS reinstall on my ReadyNAS Ultra 2
My ReadyNAS has been perfectly working up to now.
After changing both 1 To HD on my device, OS reinstall doesn't perform any more.
I've been waiting more than 36 hours but nothing happens. Both disk LED remains lit.
Disk test is OK.
How considering reinstalling firmware ? But I only found firmware upgrades on this site.
Any idea ?
Thanks.
DId you replace both disks at the same time?
What firmware are you running?
What status does RAIDar tell you? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- PlumiereAspirant
Hi,
Yes I replaced bith disks at the same time. Actually I needed old disks for another computer and I bought two brand new 1 To HD.
No idea about the firmware. Never updated, it should be the original one.
No status from RAIDar, device is not recognized (except when I do a disk check).
Plumiere wrote:
Hi,
What disk models did you install?
Do you see the NAS in the list of attached devices shown in your router?
I suggest
- testing the disks with vendor tools in a PC (lifeguard for western digital, seatools for seagate)
- trying the factory install boot option shown on pages14-15 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
Then update the firmware (which requires that disks be installed).
