jamiebeith
Sep 03, 2019Aspirant
Cannot access admin page - connection refused
I can no longer access the admin page. When I open RAIDar, it says the disk is healthy and I'm on Firmware 6.5.1 and that the IP is the same as it always has been. It also displays the same IP on ...
Marc_V
Sep 04, 2019NETGEAR Employee Retired
@jamiebeth
Welcome to the Community!
Are you having issues with data access? Have you tried to clear the web cache on your browser and also tried to use a different browser?
If this still does not resolve the issue, you may want to try doing an OS-Reinstall.
Here is the guide to do OS-Reinstall
I would advise updating the firmware as well once you have access back to the NAS Admin page.
HTH
Regards
Sandshark
Sep 04, 2019Sensei
Just to check, you are trying using user name "admin", not another you use for file access? Is it possible that you did an OS re-install and forgot you had to? That would change the password to "password".
