jamiebeith
Sep 03, 2019Aspirant
Cannot access admin page - connection refused
I can no longer access the admin page. When I open RAIDar, it says the disk is healthy and I'm on Firmware 6.5.1 and that the IP is the same as it always has been. It also displays the same IP on ...
jamiebeith
Sep 05, 2019Aspirant
I should say that I have tried to clear the cache and cookies to no avail.
Will reinstalling the OS delete my data?
Sep 05, 2019Guru - Experienced User
No (unless something goes horribly wrong). A factory default will, so be careful not to do that.
Instructions are on page 24 of the user manual here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
The OS reinstall will
- partially reinstall the operating system from the image in the flash
- reset the admin password to password
- set the network configuration to use dhcp (and disable link aggregration if used)
- turn off volume quota (on the volume settings wheel).
