readynas1001
Apr 07, 2017Aspirant
Cannot access admin page
Hello everyone, i was in my admin page and inadvertantly turned off the remote vpn option. I'm not able to log back into admin page after that in my readynas 316. Is there a way to get back into t...
mdgm-ntgr
Apr 07, 2017NETGEAR Employee Retired
readynas1001
Hello, i turned it off myself. the system has always been running slow and i was trying to disable ipv6. i tried to direct connect my laptop to the unit and access the admin page. the readynas defaulted to an ip and i set my laptop to a static ip to be on same network. i got to admin page login but the login/password would not accept. thanks for your help.
- mdgm-ntgrApr 07, 2017NETGEAR Employee Retired
If you can't login as the 'admin' user you could use password recovery or if that is not setup try an OS Re-install: How do I access the boot menu on my ReadyNAS 316, 516, 716?
- readynas1001Apr 07, 2017Aspirant
password recovery not set up. i am backing up all my data (which will take a while) and i will try an OS Re-install. Does the OS Re-install delete any data? thanks for all the help.
- xiao123Apr 10, 2017NETGEAR Expert
No. It will reset the network configuration to use dhcp, and reset the admin password to password. Other settings and data should not be affected
