Tristyd
Oct 22, 2024Aspirant
Cannot access ReadyNAS 2100
I've just brought a 2nd hand ReadyNas 2100. I've done a factory reset, not sure how long this takes btw, its been 10min ish, atm HDD light 2 & 4 is flashing and 1&3 is permanently lit. My Unifi R...
Oct 22, 2024Guru - Experienced User
Tristyd wrote:
Good news, it's a V2 2100! How do I update to the latest software?
Are you asking how to convert the NAS to run OS-6?
Tristyd
Yes 🙂
- StephenBOct 22, 2024Guru - Experienced User
I recommend increasing the RAM before you begin. Shipping OS-6 NAS have at least 2 GB of RAM, your ReadyNAS only has 1 GB. It might work, but there have been folks who have run into out-of-memory issues after converting. The upgrade is inexpensive, and is simple to do. If you aren't sure what to purchase, you can open the chassis and examine the RAM that's already installed in order to find something compatible. (I believe some RN2100v2 systems have ECC memory, others do not).
Also, if you have the skills, you should probably back up the VPD before conversion. More information on this is here:
The conversion steps are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
Note that if you ever need to do a USB recovery later on, you will need to use the procedure for 4.2 systems - substituting an OS-6 image for the 4.2.31 one.
