346gnu
Sep 10, 2018Aspirant
Cannot install iDrive_armel.deb
Hello All,
Readynas 424
4x10TB disks
firmware 6.6.2
Chose the DEB file for the above model which turns out to be
Version: 1.01.00
Released: 06-21-2018
When I select 'UPLOAD'...
Sep 10, 2018Guru - Experienced User
You apparently selected the arm download. But you have an intel-based NAS, so you should have selected the x86 version.
- 346gnuSep 10, 2018Aspirant
Yes, I spotted that
But that's the way the filter at the following link worked
https://www.idrive.com/netgear-backup#dwnld
So I got
idrive_1.01.00_amd64.deb
from
https://apps.readynas.com/pages/?page_id=9
and the result is the same, won't install
Thanks
