b4ndit90
Oct 09, 2016Aspirant
cant install system
Hi all today i buy from second hand RNAS RND4000 v2. and i have problem with this machine. When i start without HDD i can go to admin padge. when RNAS connect to router.
When i plug in my hdd form ...
Sandshark
Oct 09, 2016Sensei
I suspect that you intended for all of the data on that drive to be available on the NAS, which is not what would have happened. If so, you are lucky that nothing happened. A NAS is not at all the same thing as a case for drives, like for USB. It's a LINUX based server, and it needs to format it's disks in a LINUX compatible way.
The NAS will not operate without any drives installed. You need to install at least one drive and perform a factory default. Note, again, that everything on that drive will be erased.
b4ndit90
Oct 10, 2016Aspirant
When i plug in new hdd form shoop i have msg Wating for RAID and time 10 min move down what next ?
- b4ndit90Oct 10, 2016Aspirant
I read in weeb i can plug in only
NAS Optimised
HDD .. did i can plud ing normal hhd from pc ? and some how setup then ? or only way buy
WD Red xxxTB NAS Optimised 3.5 inch SATA III Hard Drive
- StephenBOct 10, 2016Guru - Experienced User
What ReadyNAS model do you have?
Netgear does maintain a compatibility list that includes some desktop drives. These lists aren't always up to date.
I always recommend NAS-purposed drives like the WD Reds or enterprise drives. NAS-purposed drives are close to desktop drives in price, generally have better warranties, and are intended for NAS use.
- xiao123Feb 21, 2017NETGEAR Expert
Hello b4ndit90,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards
