slmzD's avatar
slmzD
cant login
hi.. just restarted my router.. my ip on my 104 changed and now my username and password wont work on the "web browser" any more :/
anyone know what's up with that?
  • Unfortunately, support only cover for first 90 days since initial purchase
  • StephenB's avatar
    You can still use support.netgear.com.
    I am confused on your model number though - you say you have RN104 using firmware 4.1??? The NV+ v1 uses 4.1.x firmware, the RN104 runs 6.x.x
    BTW The default password for 4.1.x firmware is netgear1.
ProSupport for Business
