MichalPavlik's avatar
MichalPavlik
Can't manage my ReadyNAS102
Hallo there,
I'm sorry if this problem is there solved somewhere, but my english is not so good to find it.
If I want to manage my Ready NAS102 from page readycloud.netgear.com (where it was finded by S.N.) I have to put there account name and passworwd. In instalation guide I find it is "admin" and "password". But it doesn't works.
If I want to upgrade firmware (on OS 6.2.5) (that was recomanded in some discussion), my computer writes me: (sorry its translate from czech) There are problems with connection of file.
If I want to instal ReadyCloud on my PC, in begining of instalation it writes: "Error opening file for writing: C:\Program Files (x86)\NETGEAR\Remote\bin\inregasm.exe   Click Abbort to stop the installation ..."
If I click Retry its going again and again, if I click Ignore then installation continues to the finish, but program is only initializing and do nothing.
For info: When I opened my NAS in home network I find other files then .jpg (and folders) today first time after one month after tranfering all my work there (.raw, .psd, .tif)
OS Win10 x64 and I tryed it also with all protection turned off.
I'm photographer not an IT, so please by kind with terms :-)
Thank you very much for help
Michal
    • MichalPavlik's avatar
      MichalPavlik
      Finaly I finded this advice:
      Luminary
      bedlam1
      Re : RN10200 Cannot login to admin, Unable to reset Password
      OK you need to perform a OS Re-install as shown on Page 19 here
      This will reset the user login//password to the default values.
      These are:
      Login: admin
      Password: password
      It will also change some of your Internet protocol settings to defaults
      DO NOT perform a Factory Default as it will delete all of your data
      And it helped fix all my problems.
      Thank you very much mdgm and bedlam1
ProSupport for Business
