schuey97
Aug 10, 2012Aspirant
CASE # 19178126 - Readynas 2100 Ethernet Issues
Hey all Has anyone had an issue with the Readynas 2100 unit where you boot the device up but the RAIDar dosent pick up the device. You then take out the network cable from the ethernet port, re-sea...
mdgm-ntgr
Aug 10, 2012NETGEAR Employee Retired
You may wish to open a support case e.g. at my.netgear.com and ppost your case number (edit the thread title i.e. subject of first post in the thread to include it).
Latest firmware is actually 4.2.21: http://www.readynas.com/RAIDiator_x86_4_2_21_Notes
Please update to 4.2.21 and see if that makes a difference.
