Slise
Jan 16, 2016Aspirant
Changed to DHCP and now RAIDar isn't seeing ReadyNAS
After months of trouble-shooting to regain access to my ReadyNAS NV, I was finally able to login to the admin panel. Apparently the differing IP address on the drive (versus the IP addresses on my network) prevented me from accessing it previously. I was advised to change the IP configuration to DHCP so that it could automatically change the IP based on the network. But now I can't access the drive, RAIDar doesn't see it at all, and I have no idea what the new IP address is. I selected DHCP from the Mac network settings to see if it would identify what the new address is, but when I try that IP address, it won't connect. I should have left it alone and simply got my data off the drive before making this change. Ahh!
Please help!
Details:
Direct connection via ethernet
Mac OS
ReadyNAS NV (12 years old)
- SliseAspirant
BrianL
This model is so old, it doesn't have an LCD screen. Only 4 lights indicating the hard drives, power... The hardware is working fine; it's a software thing of simply connecting to the right IP.
- SliseAspirant
Wouldn't an OS reinstall, delete all the data on the drive?
BrianL2 wrote:
Hi Slise,
Last option you can do is to perform OS Reinstall (steps are found here).
Maybe try removing the network cable from the NAS; rebooting the router; and then reconnecting that cable first.
Is the PC you are running RAIDar on using WiFi or ethernet?
As mdgm says, and OS reinstall will reset the IP address, but won't resolve other possibilities like an full OS partition. (Neither will my suggestion btw).
