larsgorm
Feb 27, 2012Aspirant
Choice of wireless router
Hi. Can anybody give me some advice regarding choice of router. I am currently using Apple Airport Express as my main router, and regarding read and write speed to and from my Readynas Ultra 2 I...
larsgorm
Thx for your advice. Is it possible to dedicate the 5 GHz specifically to my NAS so that file transfers to and from that device will go as quick as possible (streaming for example)?
By the way do you use ur NAS for your iTunes library? I unfortunately cannot of some reason set this up in the right way so that the 3 of us in my house can sync our iOS devices to and from the NAS (from different computers)
And one last question: How does iTunes streaming server work (which I can enable in Frontview) Is it possible in that way to use (stream) the iTunes library from our mobile devices, without having to turn on one of the computers?
