chuck2go's avatar
chuck2go
Configure APC Powerchute (UPS) on RN214
Re: NAS RN214 Firmware 6.10.3
       APC BR1500MS UPS
I am attempting to install/configure APC Powerchute auto shutdown s/w on the
RN214. It appears that I'll need some instructions to get that done. I read all the
related online info, but got no where. One doc  tells me to go to the 214 admin
page and select UPS. Another tells me to select Add-ons. I could not find references
to either on the admin page.
Is this even possible?
Thanks
  • StephenB's avatar
    Sandshark might know.
    But in general, you don't need it.  The NAS already has Network UPS Tools built in, and it will automatically monitor your APC UPS if you plug in the USB cable.
  • I am not aware of a Linux version of PowerChute that will work on an UPS connected via USB.  If you do have a network card in your UPS, then the instructions (which require using SSH on the NAS) are here: Powerchute-network-shutdown-installation-on-linux.
    But the NAS has Network UPS Tools (NUT) already installed.  If you just plug the UPS USB cable into the NAS, it should recognize and configure the UPS shut-down.  You don't have the same visibility into the UPS as with PowerChute, but it properly protects your NAS by doing an orderly shut-down when the battery gets low.  The UPS configuration is located on the System/Power page of the GUI.
    FYI, Eaton does have a Linux version of their software (Eaton Power Protector) that works with a USB connected UPS and can even monitor one NAS installation from another (or between a PC and UPS).  But the NUT software also sees the UPS at boot and the two can't talk to the UPS over the same interface.  The result is neither works till the UPS is removed via the GUI after every re-boot.  I have not figured any way to turn off Netgear's automatic creation of a NUT configuration file and starting monitoring  when it finds an UPS present on a USB port at boot time.  So even if you find a version of PowerChute for Linux that supports a USB interfaced UPS, you'll likely run into the same problem.
    • chuck2go's avatar
      chuck2go
      First, I apologize that I didn't specify that I'm using Windows 10 on associated PC's.
      I had assumed that the USB ports on the front of the UPS are just for charging.
      I did connect a USB cable between the UPS and the RN214 NAS and rebooted the NAS.    However, I did not see any reference to the UPS displayed by the NAS.
      Is there a way to find out if the NAS and UPS are communicating? Also, can I configure anything related to the auto-shutdown?
      Thanks
      • StephenB's avatar
        Look on the power tab of the web ui.  There's a UPS section there that you can expand (which has some settings).
ProSupport for Business
