chuckk9033's avatar
chuckk9033
Confusion About Syncing ReadyNAS with Amazon S3 Pre-existing data
Replacing an older ReadyNAS with the 2304.  The new NAS is populated with the files from the old NAS and those files are also already in Amazon S3.  If I connect the new NAS mapped to the correct buckets and file paths, is there a chance that the files will duplicate given there is a new NAS now?
  • Well, it seemed to work except all the file dates changed to the current date vs. the real date of the file.  Anyway, it's all fine.  Thanks.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    chuckk9033
    Welcome to the Community!
    Since they are on the same drive and nothing has changed but the chassis and also the same settings and aithentications are correct, there is a chance duplication of files will not occur. If ever, it is also possible that it will be synced with a different name.
    HTH
    • chuckk9033's avatar
      chuckk9033
ProSupport for Business
