Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
Retired_Member
Nov 08, 2014Hello vandermerwe. Thank you for your interest in my problem. I understand what you said about upgrading the firmware but after the 4 drives are in and I power the NAS back on at what point can I insert the drive that I used to upgrade the system. I will be buying 1 Seagate NAS HDD ST4000VN000 (Which is identical to the other four that I have) to do the upgrade but at some point I wanted to add that one to the other four. Especially because It will be costing me close to $200.00. Will it be usable after it has helped me upgrade?
After the NAS has read all the other four drives and I turn it off can I then add it in?
Or should I just get a cheap drive and throw it away after it's done it's job?
I don't have a router or internet access. I moved to an isolated area in the woods. No internet access whatsoever. The AT&T's Netgear Unite 770s Aircard is a Wi-Fi card. I think it picks up the signal from sattelites.
Again, Thanks to mdgm and of course to you vandermerwe. You two have a nice weekend. I'll let you know if I run into any problems.
