Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
mdgm-ntgr
Nov 08, 2014NETGEAR Employee Retired
You could use a 314 with 4 or less disks. However if the 316 had more than 4 drives installed then migrating the existing array to a 314 would not be possible.
Migration of an array from a 316 to a 104 is not something we'd support and I think wouldn't work. Migration from a 104 to a 316 would be something that should work (more likely to work if no apps are installed).
