Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
vandermerwe
Nov 09, 2014Master
Yes, for the firmware update a manual update is fine. If you don't want the nas to connext directly then of course you can continue to use a direct connection. You may need to change the network settings of the PC so that it still connects to the 4g card, or change the IP address of the nas so that it is still reachable from the PC . ( use a static IP address on the nas to achieve this.
If your PC can connexc to the internet, download the firmware file, unzip it if necessary, then do a manual update from the nas.
