Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
xeltros
Nov 10, 2014Apprentice
I wasn't clear on what I meant, let's rephrase it.
I personally don't use plex but I think its two main perks are a cleaner library and media availability that is achieved by transcoding if the target device can't read the original file. That's why I would use it for.
AFAIK, the ReadyNAS DLNA server isn't able to do transcoding. So if this transcoding part is needed then, you might want t stick with plex, but if it isn't using the standard DLNA server could be an option.
