Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
Nov 10, 2014Guru - Experienced User
Yes, the library scanning would be missing.
mdgm wrote: If you don't have an Internet connection you can still use the non-Plexpass features but of course updating your library with info on shows, artwork etc. from library scanning wouldn't work without an internet connection.
There is one another option, which is to use the NAS purely as a file server - connecting it directly to the PC via ethernet and mapping drive letters to the media files. Then install the plex server on the PC (and don't use the one on the NAS). That isn't as flexible as adding the extender, but it is potentially viable.
