Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
xeltros
Nov 10, 2014Apprentice
Does the LTE device have ethernet ? I was under the impression it was only wifi.
When I say router, I mean ethernet, I should have made it clearer indeed, saying wifi on one side and nothing on the other side is not a good choice, I'm just too used to consider ethernet as the default.
Router can be the extender here too, I don't see a difference between a router with extending capabilities, and an extender with router/switch capabilities unless you are dealing with multiple subnets.
