Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
vandermerwe
Dec 05, 2014Master
With regard to the subnet, you can't access the GUI , is that correct?
You can reset the network settings by doing an OS reinstall using the boot menu. I think you should read the hardware and software manuals, it will help you understand the device that you have.
http://www.downloads.netgear.com/files/ ... ct2013.pdf
