Retired_Member
Nov 08, 2014Connect ReadyNAS directly to pc without internet?
Can Seagate NAS HHD 4TB hard drives that were in a ReadyNAS 316 be used in a ReadyNAS 104 4-bay Diskless or a ReadyNAS 314 4-bay Diskless? Does it matter what order they were in? They were mixed up. ...
Dec 05, 2014Guru - Experienced User
ReadyNAS remote won't work unless you have internet access to the NAS.
RAIDar won't work unless you match the subnet mask. If you can't change the one in the NAS, then change the one in the PC.
vandermerwe - if the NAS is set for DHCP, and failing over to 192.168.168.168, he probably can't change the subnet mask. And there's no need, he can easily change it on the PC.
