DempaX
Jul 11, 2012Aspirant
Considering buying Ultra 4
Hi, I have unused 1TB plus 2x1.5TB disks at home I'd like to make use of for storage, backup and streaming. A four disk NAS feels like the best way and I am considering a good deal on Ultra 4 + 1x2...
Jul 12, 2012Guru - Experienced User
Looks more carefully at that step. A 500 GB drive is replaced with a 1.5 TB drive, but the available space only goes up 500 GB. The remaining 500 GB on the drive is wasted until a second 1.5 TB drive is added. So yes, you can put in three sizes, however there is always wasted space when you do.
There is more information posted here: viewtopic.php?f=25&t=48983.
There are two other limitations not described in that particular thread. The first is that you can't add a smaller drive: (viewtopic.php?f=66&t=32864)
That second is that the volume size cannot be expanded more than 8 TB beyond its initial size: (viewtopic.php?f=66&t=62917&p=352749&hilit=8+TB#p352749)
