Max_Marthini
Mar 08, 2020Aspirant
data DEGRADED
I received the message "data DEGRADED", and it seemed as disk 3 was not working. So I replaced it, but I get the same message: "data DEGRADED", and disk 3 is not visible on my admin page. What should...
Marc_V
Mar 08, 2020NETGEAR Employee Retired
Welcome to the Community!
Have you tried reinserting the disk? The disk should be detected by the NAS, it might have not completely got inserted when you replaced Disk 3 and try to reboot your NAS if possible f you have done this already try checking the disk replacement on a PC if it will run to make sure that you have a good disk. Otherwise, it might be a SATA issue, replaciing it by Support would be best.
HTH
Regards
