atebit
Apr 21, 2012Tutor
difference between the ReadyNAS models?
I have an original ReadyNAS (not even a "+") that is at least six years old at this point. Still running the original disks (1TB). No issues with the disks at this point. The chassis is OK, though ...
mdgm-ntgr
Apr 21, 2012NETGEAR Employee Retired
The NV will support 2TB drives but you'd likely need to do a factory reset on RAIDiator 4.1.7 or later. Most 2TB disks are 4k sector and without 4k sector partition alignment you'll get poor write performance.
If you're looking for a new model I'd go with the x86 (Intel) range i.e. Ultra/Pro. These are much faster than the NV, support disks larger than 2TB in capacity, run a greater range of add-ons, have more features etc.
I like features such as the "Disk Test" boot option which allows you to run long SMART tests on drives.
If you want to stick with the NV you might wish to consider replacing the fan. If you do get a new NAS it'd still be useful for a backup unit.
