atebit
Apr 21, 2012Tutor
difference between the ReadyNAS models?
I have an original ReadyNAS (not even a "+") that is at least six years old at this point. Still running the original disks (1TB). No issues with the disks at this point. The chassis is OK, though ...
ReadySECURE
Apr 21, 2012Apprentice
atebit, while it appears mdgm was able to resolve your query regarding the difference in models, allow me to direct you to this link, which will present you with a comparison chart for both the business and home ReadyNAS units: http://www.readynas.com/?cat=49 . Also, the factory default will need to be performed when the 2TB Drives are in the unit.
