zeke561
Jul 18, 2011Guide
Disaster Strikes! Advice requested!
I have an NV+ that has failed in a way that I have not seen. If I try to power it up, I see that the 2nd and 4th disk status LEDs are not lit. The power LED blinks a few times and then goes out, then nothing, no indication of any activity at all. This doesn't seem like normal disk failure, but I tried to put new disks into the 2nd and 4th slots, with no change in behavior. I am aware that the RAID can't tolerate two disk failures, so I don't really know what would be the symptoms or how to proceed if this is the only problem (I'd be kind of relieved if it is). I would appreciate any guidance on this, because if at all possible I need this device as a backup server for quite a bit of data.
thanks
thanks
- PapaBear1ApprenticeNot really. If the drive in your PC died, and you did not have a clone, then when you put the new drive in, you would insert the install disk, install the OS and then go through the set up to customize the BIOS settings. The flash memory with the OS simply replaces the install disk (since there is no CD/DVD drive).
- jsdepreyAspirantSeems like a strange way to do it to me, why not just have a small 4GB flash drive for the OS in the NAS? and the Array for stored data? seems more logical to me really. I was told by tech support that the OS is only installed on 1 of the 4 drives in my NV+ and that is a BASE drive and if that drive dies you can not ell what is wrong with the NAS, like it wont boot up, till you remove that drive, even though my NAS did not show any drive LEDs out at all, and my BASE drive was dead or having issues of some kind. was a very strange problem and made me think that this was not the way to go, installing the OS on a single drive in the array seems strange.
jsdeprey wrote: installing the OS on a single drive in the array seems strange.
its not stored on a single drive (unless there is only a single drive installed).
I'm not sure of the exact format, but the os partition is at least mirrored to one other drive, if not in a raid0+1 array.- sphardy1Apprentice
TeknoJnky wrote: jsdeprey wrote: installing the OS on a single drive in the array seems strange.
I believe it is RAID-1, such that the OS is mirrored across all drives and always accessible irrespective of which drive fails/is removed
That's why the capacity of each drive is reported as reduced by 4GB (for x86 units) in Frontview >> Volumes - the 4GB being the root partition
