MarcusRosen
Sep 30, 2016Aspirant
Disc degraded after Firmware upgrade to 6.5.2
Hi, My NAS have been working fine with the only issue being very slow acces via Windows Exporer. I turned of the real-time anti-virus scanner and the issue went away. I then updated to the ...
Sep 30, 2016Guru - Experienced User
I think it be wise to shut down the system and test disk 2 in a windows PC with lifeguard. If you don't have a backup you should certainly make one - your data is at risk.
One way to proceed is to back everything up, do a factory reset and then rebuild the NAS, and restore the data.
There are some odd things going on in the logs. hopefully netgear will take a look. spindown.log enables spindown on disk 2, but the disk never is spundown. This goes back to last June (as far as spindown goes back), so it is not new.
disk_info.log only shows disk 1. smart_history shows both disks (and both have a couple of pending sectors errors).
There are a couple of other issues going on, which I don't really understand the cause.
One is this snippet (which repeats)
Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.607780, 0] ../source3/smbd/oplock.c:192(update_num_read_oplocks)
Sep 29 06:52:31 Rosen-NAS smbd[23255]: PANIC: assert failed at ../source3/smbd/oplock.c(192): d->num_share_modes == 1
Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.611268, 0] ../source3/lib/util.c:788(smb_panic_s3)
Sep 29 06:52:31 Rosen-NAS smbd[23255]: PANIC (pid 23255): assert failed: d->num_share_modes == 1
Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.612039, 0] ../source3/lib/util.c:899(log_stack_trace)
Sep 29 06:52:31 Rosen-NAS smbd[23255]: BACKTRACE: 0 stack frames:
Sep 29 06:52:31 Rosen-NAS smbd[23255]: [2016/09/29 06:52:31.612518, 0] ../source3/lib/dumpcore.c:318(dump_core)
Sep 29 06:52:31 Rosen-NAS smbd[23255]: dumping core in /var/cores
There are also regular ethernet over-runs, which might be related to your poor performance.
Sep 29 19:22:26 Rosen-NAS kernel: [395773.553715] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
Sep 29 19:22:29 Rosen-NAS kernel: [395775.997205] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
Sep 29 19:22:35 Rosen-NAS kernel: [395782.477936] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
Sep 29 19:22:35 Rosen-NAS kernel: [395782.477960] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=512
Sep 29 19:22:39 Rosen-NAS kernel: [395786.820422] mvneta d0074000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
mdgm-ntgr
Sep 30, 2016NETGEAR Employee Retired
The disks may have hardware issues. This wouldn't be caused by the firmware upgrade.
Do you have a backup?
