MarcusRosen
Sep 30, 2016Aspirant
Disc degraded after Firmware upgrade to 6.5.2
Hi, My NAS have been working fine with the only issue being very slow acces via Windows Exporer. I turned of the real-time anti-virus scanner and the issue went away. I then updated to the ...
kohdee
Sep 30, 2016NETGEAR Expert
It is unlikely that your disk failed due to an upgrade. Typically, if you have used a disk for awhile but you aren't processing much data on it (it just sits around), then you don't activate any bad sectors, but upgrading/rebooting might cause it to pass over bad sectors and fall out,.
It looks like your drives have counted up a few errors historically (see smart_history.log), but not too many.
On Sept 30 around 19:33:16, your disk tried to come online but it was having some kind of read errors.
You can see constant complaints in the dmesg.log trying to identify the disk.
[Fri Sep 30 19:34:15 2016] ata1.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
Your drive in bay 2 seems to have been collecting errors, as well. Not too many though.
- MarcusRosenSep 30, 2016Aspirant
Thanks for all the replies. :)
I'm backing up all the data on external drives right now (likely to take some time).
Is it likely that I need to replace the Bay 2 drive or could it be the NAS itself?
How can I proceed one all the data is backed up?
- mdgm-ntgrOct 01, 2016NETGEAR Employee Retired
You can hook the disks up to a PC and test them using the vendors tools e.g. SeaTools for SeaGate disks or WD Data LifeGuard Diagnostics for WD disks.
