MarcusRosen
Sep 30, 2016Aspirant
Disc degraded after Firmware upgrade to 6.5.2
Hi, My NAS have been working fine with the only issue being very slow acces via Windows Exporer. I turned of the real-time anti-virus scanner and the issue went away. I then updated to the ...
MarcusRosen
Thanks for all the replies. :)
I'm backing up all the data on external drives right now (likely to take some time).
Is it likely that I need to replace the Bay 2 drive or could it be the NAS itself?
How can I proceed one all the data is backed up?
mdgm-ntgr
Oct 01, 2016NETGEAR Employee Retired
You can hook the disks up to a PC and test them using the vendors tools e.g. SeaTools for SeaGate disks or WD Data LifeGuard Diagnostics for WD disks.
