dgcasting
Jan 17, 2018Aspirant
Disc upgrade fail
4 bay ready nas, set in raid 1: C and D. C drives were 1TB and out of room. I hot swapped over 2 days to 2 TB drives. System works, files intact. But, the READYNAS does not see the 2 TB of space...
Jan 18, 2018Guru - Experienced User
I'm not sure why you needed to use the pinhole to access the boot menu. Was the NAS hung?
The simplest (though brute-force) approach is to do a factory reset and restore the data from backup. Alternatively you could use paid netgear support (my.netgear.com).
If you can boot normally (by just powering up the NAS) you could destroy the old 1 TB volume, create a new one, and then restore the data on that volume.
- dgcastingJan 24, 2018Aspirant
I used the pin hole to access the boot up menu as that is what the Manual said to do. But this failed.
The discs are all working fine. But Volume C which is what I upgraded to 2TB is still showing only 1TB of space.
RAIDAR still shows this volume (Raid 1) at 80% full when it shoudl be about 40%,
How do I get the system to "see" the increase in capacity?
- StephenBJan 24, 2018Guru - Experienced User
I'm not 100% sure, but I am thinking that flexraid might not support vertical expansion on the OS 4.2.x systems.
If I'm right, you'll need to back up the data, destroy the C volume, and then create a new one. Then restore the data from backup.
What boot option did you want to use?
Thanks,
I was affraid of this answer. The manual just said to use the BOOT menu, BOOT Normal and it will adjsut the size.
I suppose like many things with Netgear it was wrong. I will connect a ne USB drive and back it all up. 1TB of video and photos.
Thanks,
