AMRivlin's avatar
AMRivlin
Apprentice
Jan 30, 2012
Drive Compatibility List - Updated Often?
I just purchased a Pro 6. I am considering purchasing 3 2TB WD20EARX. This drive is listed compatible for some ReadyNAS, but NOT the Pro6. Is it possible the list is out of date?
WD20EARS IS listed for the Pro6, what differs between S and X?
My decision for the WD20EARX is based solely on price $129 per drive. Is there a better drive to select in that price bracket?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    No, the ReadyNAS models for which the WD20EARX is on the compatibility list are very different to the Pro 6. Stick to the compatibility list.
    I'm not sure, but I do know that the drives are different. Support will be denied if you use disks outside the compatibility list.
    Maybe look at Hitachi or Samsung
  • Newegg has the WD20EARS in stock for $10 more than the WD20EARX.
  • Thanks, the Seatac ST2000DL003 is on the list and is 129.99 with the same specs.
    You may want to check this post before buying those drives. Summary: many people have had severe problems with them.
  • Ok thanks for the information. Any particular drive that is recommended?
ProSupport for Business
