mmartinez1
Apr 24, 2014Aspirant
Drive configuration ReadyNas 102
I received my ReadyNas 102 2 days ago and after going to many sites and reading, I was able to start the unit. I currently have one 2TB and one 1TB drives and do not have the means to purchase anothe...
Apr 24, 2014Guru - Experienced User
You need to set up the unit as flexraid.
Generally it works best to set up one volume per disk. That would give you a 2 TB volume and a 1 TB volume - 3 TB total.
You could also set up a 2x1TB RAID-1 volume that has RAID redundancy, and then set up a second 1TB volume with no redundancy. That would give you 2 TB of total space.
To get there from where you are, you can either do a factory reset, and rebuild from scratch. Or change to flexraid, and if needed, destroy your existing volume.
