mmartinez1
Apr 24, 2014Aspirant
Drive configuration ReadyNas 102
I received my ReadyNas 102 2 days ago and after going to many sites and reading, I was able to start the unit. I currently have one 2TB and one 1TB drives and do not have the means to purchase anothe...
Apr 26, 2014Guru - Experienced User
Xraid/flexraid are modes for the whole unit, they don't apply to specific volumes.
mmartinez wrote: If I want to try your second alternative, "2x1TB RAID-1", would I select X-Raid on the 2 TB Drive and leave the 1 TB alone?
If you are using flexraid, you first put both disks in a RAID-1 array. You should then be able to create a second 1 TB RAID-0 volume on the 2 TB drive to use the extra space if you wish.
With xraid, the system simply gives you a 2x1TB RAID-1 array, with no way to use the extra TB.
