mmartinez1
Apr 24, 2014Aspirant
Drive configuration ReadyNas 102
I received my ReadyNas 102 2 days ago and after going to many sites and reading, I was able to start the unit. I currently have one 2TB and one 1TB drives and do not have the means to purchase anothe...
Apr 26, 2014Guru - Experienced User
You destroy the volumes, then recreate them. For the first one you select both drives. OS4 allows you to enter the desired volume size. I don't recall if OS6 does that or not (I created my OS6 volumes quite a while ago).
After that finishes, you should be able to create a second volume on the larger drive.
Note I haven't created a RAID-1 volume on the RN102- I use jbod, which is what you have already set up. OS6 might be more restrictive on flexraid than OS4.
