mmartinez1
Apr 24, 2014Aspirant
Drive configuration ReadyNas 102
I received my ReadyNas 102 2 days ago and after going to many sites and reading, I was able to start the unit. I currently have one 2TB and one 1TB drives and do not have the means to purchase anothe...
Apr 28, 2014Guru - Experienced User
The way you would do RAID-1 is select both volumes. Alternatively, let it use XRAID with both volumes in place, and immediately convert to flexraid after the volume initializes.
