rjameson
Jul 10, 2014Aspirant
Drive failed, replaced - but does not resync
I have a readynas pro, 5 drives in dual drive redundancy...had 3 show smart sector errors - so was going to replace one at a time. I put a new drive in the open slot #3 (thinking it would be a hot...
vandermerwe
Jul 10, 2014Master
The volume shows as redundant then?
If the volume is redundant then I would remove disk 4 with the NAS on, wait until the NAS sees it's out then reinsert it with the NAS still on, the NAS should start a resync and expand the volume.
If this does not work, I'd remove the disk 4, attach it to a PC, check it with vendor tools and delete any partitions that are on the drive, then reinsert it.
It that doesn't work then contact support.
Of course you should always have a backup of the data on the NAS.
