JPT1
May 25, 2015Aspirant
Drive Trays sold separately?
Hi, I've got a ReadyNAS DuoV2 and a 104. Both use a similar tray system... Are these trays available separately? And are there any 5,25" bays you can build into you PC to insert those trays? ...
May 26, 2015Guru - Experienced User
Yes. Do be careful not to buy the tray for the old rackmount ReadyNAS (1100, etc). They won't fit in the desktop chassis.
Nhellie wrote: Here's the part code/model number of the ones displayed on Amazon
RND4TRAY1-10000S
