kylepaddock
Oct 21, 2018Follower
Dual LAN connectivity
I am looking into getting the ReadyNAS 422 to store media files and some documents. My issue is I have 2 computers that are on LAN 1 that has internet and 2 devices that are on LAN 2 that can not have internet. I understand aggregation but can I use one port for LAN1 and the other for LAN2? Also Is there a way to access files then through windows explorer just like if I had an 2nd hard drive installed?
Hi kylepaddock
Welcome to the Community!
VLAN Support has been added since OS 6.6.0. You just need to go to the Network settings and create the VLAN you need for the NIC you will be using.
You can Map Network drives to your computers if you need to get access to it and use it as drives as well.
Hope this helps!
Regards
1 Reply
- Marc_VNETGEAR Employee Retired
Hi kylepaddock
Hope this helps!
Regards
