bytte
Dec 02, 2014Aspirant
Duo stops listening
I have an original Duo that appears to stop receiving packets from the network soon after boot. Eg stops answering pings, but continues to send SSDP packets. Changed it's network port on the hub. ...
Dec 02, 2014Guru - Experienced User
Sounds like a full OS partition (not the data volume).
If you have enough time, try deleting the logs in the short bootup window (first system, and then backup). Netgear (including mdgm) have other ways to do it.
Do you happen to have ssh installed?
