rnas_newbie
May 07, 2012Aspirant
Duo V2 : Remote UPS monitoring:sorted v.5.3.7
edit - **sorted in raidiator 5.3.7**
I've had a quick search on the forums and drew a blank...but in the true tradition of the older models;
Please can we have the ability for the Duo V2 to monitor the UPS status from another Readynas?
I was somewhat taken surprised this feature had been removed from these newer models, and they have been out a fair few months now.
- mdgm-ntgrNETGEAR Employee Retired+1. This is a feature I'd like to see added too. Might not make 5.3.5 though if they add it (there's a limit to how much can be added in a single firmware release) but hopefully a later release.
NetGear is well aware of this request. The more people that request this feature the more likely we are to see it. - pogacsaAspirant+1 pls
- StephenBGuru - Experienced User+1 Though I do not own a V2 right now, remote UPS monitoring is something I use today. I wouldn't upgrade to a V2 unless it had this feature.
- llevetAspirant+1
Please staff, feed back us that is in progress.
Thank's.
Ludovic. - llevetAspirantTo workaround of lack of support for Remote UPS monitoring (in readynas Duo V2) follow this :
Connect to your readynas in SSH then :
- Modify file /etc/default/nut with vi to have :
# start upsd
START_UPSD=no
# start upsmon
START_UPSMON=yes
- Modify file /etc/nut/upsmon.conf with vi to have :
#MONITOR UPS@localhost 1 monuser pass master
MONITOR [email protected] 1 monuser pass slave
remark : 172.31.31.249 is the ip of the remote server, change it by yours.
- create a dummy file ups.log by :
touch /var/log/frontview/ups.log
- Start the deamon UPS
/etc/init.d/ups-monitor start
It is done !
To verify if it works :
cat /ramfs/ups.info
it will give you something like :
APC Smart-UPS 1000!!100.00!!52
Go to front view, the icon of ups is green, and mouse over give you the info.
Ludovic.
:D - rnas_newbieAspirantthanks Ludovic for the tip :)
I tried the workaround, and all is well for a while - but there seems to be a problem when I reboot, the V2 seems to delete the ups.log file and the ups monitor on frontview is no longer green. Is this a limitation or should i try a reinstall from scratch incase i did anything wrong?
ps - i really do wish the Jedi would confirm a long term/built-in solution is going to be offered soon :( - mdgm-ntgrNETGEAR Employee RetiredProbably have to update the sqlite3 database for it to retain the settings. We'll need to keep on asking them to add features like this.
- llevetAspirantHi rnas_newbie,
Yes i have see the problem with the lastest firmware (5.3.6) and i resolve it by :
vi /etc/init.d/ups-monitor
Replace :
start_stop_client () {
case "$START_UPSMON" in
y|Y|yes|YES|Yes)
case "$1" in
start)
start-stop-daemon -S -q -p $upsmon_pid -x $upsmon >/dev/null 2>&1
stop)
start-stop-daemon -K -o -q -p $upsmon_pid -n upsmon >/dev/null 2>&1
esac
n|N|no|NO|No|*)
return 1
esac
By :
y|Y|yes|YES|Yes)
case "$1" in
start)
stop)
esac
n|N|no|NO|No|*)
return 1
esac
Ludo. - rnas_newbieAspirantThanks Ludo, for the above tip.
i've made the amendment but I'd like to confirm if I need to always run the following?- Start the deamon UPS
or if there is a way to automate it...? As the setting within Frontview is not active until i run the command.
apologies if the questions seem basic, I can see the logic that it probably does need to be scheduled to start, but I'm unsure where to make the amendment..
thanks for everyones help. - mdgm-ntgrNETGEAR Employee RetiredThere are multiple ways to automate something like this. One would be to do it like an add-on. Can't remember the other at the moment.
