filzip77
Jul 13, 2012Aspirant
[Duo v2] bad sectors because the two disks are different
Hello, When I bought my ReadyNas Duo v2, only 1 hard-disk was included. A few weeks later, I decided to buy a second disk but the same disk was not available anymore. I then chose an hard-disk wit...
HERBIEO
What firmware is on the seagate ST2000DM001
Edit: The latest firmware for that drive is CC4H http://knowledge.seagate.com/articles/e ... Q/223651en
If you check the HCL you will see Seagate Barracuda 7200.14 ST2000DM001 2TB 6Gb/s 64 MB Must be used with firmware CC4H or newer.
