filzip77
Jul 13, 2012Aspirant
[Duo v2] bad sectors because the two disks are different
Hello, When I bought my ReadyNas Duo v2, only 1 hard-disk was included. A few weeks later, I decided to buy a second disk but the same disk was not available anymore. I then chose an hard-disk wit...
HERBIEO
filzip77 wrote: Thank you all for your replies.
I have just upgraded the firmware of the disk. The old firmware was CC4C and it is now CC4F.
Let see if the SMART errors will continue to increase.
Do you think that these are real errors or just false errors related to the firmware? When I do deep scan (with Seatool), it finds no error. I coul then assume there is no real error ...
If something goes wrong, my most important folder is backed up with Crashplan.
Philippe
Did you read my post above or is that just a typo CC4H is the latest firmware.
If you check the HCL you will see Seagate Barracuda 7200.14 ST2000DM001 2TB 6Gb/s 64 MB Must be used with firmware CC4H or newer.
New firmware version: CC4H
Please verify your drive model number, serial number, and firmware revision using the Drive Detect software.
This article applies to the following models:
Model Number Part Number Capacity
ST3000DM001 9YN166 3TB
ST2500DM001 9YN16L 2.5TB
ST2000DM001 9YN164 2TB
ST1000DM003 9YN162 1TB
Previous versions of firmware with these models and part numbers are CC46, CC47, CC49, CC4C, or CC4G.
