andefeldt
Nov 02, 2011Aspirant
Duo with 2x2tb drives (4tb raid possible?)
Hi, I have a ReadyNas Duo with two 2TB drives installed. Can I use the two drives in a raid mode as one big drive with a capacity of 4TB? And does the Duo support 4TB usb drives as a backup driv...
andefeldt
Nov 06, 2011Aspirant
Ok. Is there any way that you can back up 4tb of data then?
I found somewhere in this forum (I can't find it now, of course) that 4tb USB drives worked, while 3+tb internal drives didn't on the duo. Would my only possibility of backup be to backup to another 4tb NAS unit via LAN?
