drjasonharrison
Sep 25, 2012Aspirant
Duo/NV+ V2 Auto-shutdown on UPS low-battery
I have a NV+ V1 (Sparc) which is giving me headaches trying to back it up. Therefore I'm looking at purchasing a Duo V2 or NV+ V2 to serve as my new home NAS. However I was looking at the comparison...
mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
The Duo/NV+ v2 will shutdown if connected directly to a UPS. It does not support the network sharing of a UPS.
You're better off going with a ReadyNAS Ultra/Ultra Plus/Pro Series device. Faster than the Duo/NV+ v2 and has lots more features.
Perhaps your issues backing up the NV+ v1 would be resolvable.
How are you trying to backup the NV+ v1? Using Frontview backup? If so, what are the backup job settings?
Are you backing up to a USB disk? Another NAS? Some place else?
