rhpot1991's avatar
May 25, 2021
Low Battery Warnings (6.10.5)
After upgrade to 6.10.5 my NAS is throwing low battery warnings randomly throughout the day.  Then all my other NAS that use this UPS remote pick up the warning, spamming my email box.  Battery is fine, everything is running on power.
I rolled back to 6.10.4 and I'm still getting the same alerts.
    And you know the battery is fine how?  The usual cause for this is that the UPS is reporting a low battery, whether or not it really is, not something within the NAS.  Most UPS will continue to power the attached devices fine with a bad battery as long as the power stays on.
    • rhpot1991's avatar
      rhpot1991
      Guide
      Display on the UPC itself says full battery.  I'll see if I can identify anything via command line, possibly move to another of my ReadyNAS to see if I get the same behavior there.
      • Sandshark's avatar
        Sandshark
        Sensei
        Moving it to another NAS would be a good way to see if it's the NAS or the UPS.  While the display says the battery is good, it could be sending out sporadic bad data on USB.  If it is the NAS and you want to return it to that NAS, deleting the UPS and letting it be re-installed might help.
ProSupport for Business
