mhellstrand's avatar
Mar 14, 2017
Echange ReadyNAS Duo v2 to new NAS
Hi
I have a ready nas duo v2 running at home with 2 3tb mirrored disks.
I wonder if I want to "upgrade" to newer (maybe bigger) model of Netgear NAS can I choose a new NAS and have my disks swapped over without any data loss?. What models are there that's compatible to this "diskswap".
many thanks
//Martin
  • Well the solution I am seeing but it is hairy and a bit dangerous is:
    setp 0 old device raid 1 redundant new device empty
    step 1 old device raid 1 degraded 1 slot empty new device 1 slot populated
    step 2 manual data transfer
    step 3 old device remaining HDD removal and low level format and insertion (mandatory if you want a clean install) in 2nd slot of new device and adding parity to have raid 1 at least.
    end of procedure.
    Reagards.
    Open to suggestions.
  • StephenB's avatar
    The newer NAS use a different file system, so you can't simply migrate them.  The RN200 series is a good place to start looking - there is a two-bay RN212 and a four-bay RN214.  The RN100 is possible too, but in my opinion is a bit underpowered (relatively slow CPU).
    Personally, I'd get new disks for the new NAS, and use the duo v2 as a backup device for the new one.
    You could also remove one drive from the duo, and do a fresh install on the new NAS.  Then copy the files over the network (using the built in backup jobs). When complete, remove the second disk from the duo, and add it to the array.  It is best to have a backup, if a disk fails in this process you could lose data.
    • aalexandrebeta's avatar
      aalexandrebeta
      Master
      I will ask you a question, WHAT IS THE MONEY you are willing to spend?
      My options I'll give you will all depends on that!
      What you really want to do in the future, 2/4/6 bays and your future needs.
      HOW many GB are you adding each years?
      Regards.
      • mhellstrand's avatar
        mhellstrand
        Tutor
        Thats not really an answer to my question.
        my only concern is "Can I swap my current disks to another NAS unit or not and still keep the data on them?"
        Why i'm asking is because i had a ready nas duo version 1 for many years and the hardware broke. Something in the NAS just died but both disks was ok. So in the event that the actual NAS breaksdown and wount reboot any more. How can I save the data on det disks if I cvan't swap them into another newer NAS unit.
        //M
ProSupport for Business
